1 - 5 of 5 Posts
Say I have a Chroma 5 and a i1D2. If I wanted to check my calibrated results done with C5 with the i1D2, is there an easy way to switch meters in CalMan and make another run in the same session or will I have to close it and restart another session to use the 2nd meter?
All that is needed is to select another meter within CalMAN while having the same cal sessions open.
Discussion Starter · #3 ·
I see. Thanks.
Premium Member
I have done this many times. If I know I'm going to use multiple meters, I make sure to have them connected when I boot the application and make sure they are recognized at meter selection time. This might not be necessary, but I do it to make sure the meter's going to be selectable when I need it for an additional run.
And, yes, Lee, if the additional meter requires initialization, you can do it after selecting it as you would normally do.
1 - 5 of 5 Posts
