Using bookshelf speakers for centers?
490 Views 12 Replies 5 Participants Last post by  Trebor Pyn
Currently, I am using 4 "vintage" A/D/S speakers for my mains and surrounds, but, since they are no longer the same company, I've been using a Cambridge Newton 500 center.
Now I've come across a pair of smaller A/D/S bookshelf speakers, and I'm wondering how they'd work as a center channel "team". I mean, splitting the center channel signal to 2 mono amps, and placing both bookshelfs vertically on top of the RPTV as a sort of "stereo center channel".
Any ideas about how well (or poorly) this might work? (aside from the possibility of magnetic interference from an unshielded speaker, that is)
Status
Not open for further replies.
1 - 13 of 13 Posts
Really? Nobody has any idea? I've read of dispersion issues, etc......
Interesting idea. Why not just use one? I assume if you set them to small, it doesn't matter if you use one or if you use two. You'd wire them parallel or series I guess. I think the timber matching would definitely be worthy. Also, you can try it with just one, and use the second as a surround back for 6.1 :)
Timbre matching is the main reason I'm thinking of doing this. I'm just not sure whether the timbre match would be offset by the dispersion "issues"....and *that* is why I'm thinking that two--toed out--might take care of all that. I'm just wondering if anyone else has tried this sort of thing and what kind of results they got.
Also, I don't have 6.1 processing in my B&K Ref20.:(
Using 2, toed-out or separated will create imaging/phase problems. Use one.
Kal
Vertically, as designed, or horizontally? And thanks for the advice...
As Kal said, do not run two center channels. Also, you are most likely going to have a rough time avoiding magnetic interference issues.
Not if he has a LCD or DLP. The shielding would only be needed on a CRT display.
One, vertically, as designed.
Kal
What possible"horrors" am i setting myself up for if i use 2 Polk R15's,horizontal,tweeter to tweeter,as a center sitting atop my display?
Mains are Polk vintage Monitor 5's
I am using one of the R15's as a center at the moment and thought i would "gain" in using the other i already have.
1. Some cancellations due to interaction between the drivers reproducing the same signals and separated in space.
2. Poor dispersion in both planes.
Kal
Thanks, Kal. Good info, as I've come to expect from this forum. Glad you're here!
{1. Some cancellations due to interaction between the drivers reproducing the same signals and separated in space.
2. Poor dispersion in both planes.}
And right you are.
It was horrible.If i sat in the now very narrow sweet spot it sounded just like the one speaker i had been using.Very good.
If i tilted my head either direction i would get this effect of center sound coming from the opposite side i was leaning too.
I am much happier with the single center speaker with the Tweeter set off center.The dialog is anchored to the screen regardless of where i sit.
I guess i just have an extra speaker for parts(or the ever elusive "overhead center channel"matrix)
See less See more
1 - 13 of 13 Posts
Status
