1 - 4 of 4 Posts
Discussion Starter #1
So my landlord recently gave me her old sub box from her car along with the amps and I was wondering if there was any way I could use them for home audio like parties. I have also attached pictures of the sub, amps and ground loop inductor.
You would need to use a 120volt--->12volt power supply to power the amp and for what it would cost to buy a power supply with enough juice for that amp, it's just not worth it. Find a cheap, used pro power amp and power the sub with that. That sub is probably 4 ohms so a cheap pro amp bridged would give you all you need. Something like this bridged to that sub would have enough power to smoke it if you wanted to. :D
http://www.parts-express.com/behringer-nu1000-inuke-1000-watt-power-amplifier--248-6700
1 - 4 of 4 Posts
