I have an old Elemental designs e12k subwoofer (d4) in a .88 cu foot box. Is it possible to use it for home audio with decent results?
Here are the specs:
Specifications
Qts: .369
Qes: .39
Qms: 4.97
Fs: 24.00Hz
Re: 1.75
Vas: 83L
Mms: N/Ag
Bl: 20.00T*m
SPL: 86.5dB
Sd: 490cm²
Xmax: 15.8mm
Voice Coil: 62.0mm
Magnet Width: 5.125"
Cutout Diameter: 11.125"
Mounting Depth: 5.900"
Weight: 0lb
Total Height: N/A"
Displacement: .08 ft³
Outside Diameter: 12.500"
And how would a HT receiver power it?
Here are the specs:
Specifications
Qts: .369
Qes: .39
Qms: 4.97
Fs: 24.00Hz
Re: 1.75
Vas: 83L
Mms: N/Ag
Bl: 20.00T*m
SPL: 86.5dB
Sd: 490cm²
Xmax: 15.8mm
Voice Coil: 62.0mm
Weight: 0lb
Total Height: N/A"
