1 - 2 of 2 Posts
Tried searching and a couple things and did not come up with anything definitive.
What I would like to do is use Zoomplayer because of it's ffdshow support. I would like to use the Creative DTS-ES / DD-EX decoders instead of just outputting through SPDIF.
Anyone have success with this? I would have expected just to set the audio codecs to use SPDIF, but that doesn't seem to get me the correct output.
I am currently using MCE 2005. I have read a bunch on why MCE cannot do it natively. I am OK with that. But any recommendations on an audio decoder to use with ZP that could do it properly? I can run WinDVD and it works just fine on the trial version I downloaded, but I don't see the same options in the WinDVD codec that the player has. Or I guess if WinDVD could utilize ffdshow, then that would work, but I thought I read that cannot happen either.
1 - 2 of 2 Posts
