1 - 20 of 21 Posts
I'm looking at acquiring a DCX2496 to try out a few active speaker designs, and have a few quick questions.
1. For those of you running unbalanced gear (RCA connectors), how are you connecting to the DCX (balanced XLR).
2. How is everyone controlling the volume? Pre xover or post xover?
Cheers.
I use RCA to XLR connections.
Volume control is done pre xover, but I have my power amps adjusted to maximize gain from the preamp.
Same; I just use adapter cables as well. Monoprice carries XLR to RCA cables, though the ones I use aren't Monoprice.
Just hooked my DCX up Saturday using the Monoprice cables and I couldn't be happier. I was worried about hum/ground problems but everything is working great. The Monoprice stuff seems very high quality for the price.
Oh, and I'm using an Onkyo 805 and an XPA-5, so I have quite a combo of unbalanced and balanced stuff all hooked together.
I too am using a home theater receiver (Panasonic XR55), Monoprice RCA to XLR cable and a DCX2496.
I can barely get the input LED's on the side of the DCX registering -20.
How are you guys getting ample input voltage allowing for proper (optimal?) A/D conversion levels without a line level converter?
I'm assuming you are using the Panny as a power amp and inputting via the 5.1 inputs, with a separate prepro before the DCX?
In that case you want to turn the volume of the Panny down. This means you'll need to turn the volume of your prepro up, which will improve the levels into the DCX.
I am using the LFE out directly into the DCX2496.
The problem I have always had with my DCX is getting the gain structure right.
I want to turn my pre/pro way up so that I maximize my DCX processing and lower its noise floor but that means other speakers that are not part of the DCX will be too loud even if I set the trim to -10. Its hard to match Gain settings when you are not using a DCX for all pre-outs IF all amps do not have volume controls. I just picked up a Panasonic XR55 to act as my volume control with all amps that do not have volume controls.
When I have time Im also going to order a DCX modification (its about $600 though). It replaces all the inputs/outputs on my DCX so that I have the proper gain structure, they will also be unbalanced to make connectivitiy easier.
Originally Posted by mynym /forum/post/17392838
Looks like the input on these is balanced XLR's. Won't work our consumer level LFE RCA outs :/
There is an RCA option but you would use this device between the DCX and the amp. The DCX has XLRs actually so do many amps (Mine do).
The idea of this device is to allow use to reduce the voltage going into an amp that doesnt have its own volume control so we can to set the gain on a pre/pro to max so that the DCX works its best
Originally Posted by mynym /forum/post/17393470
Hrm. in my case the EP2500 as attenuation controls
Yeah, if you amp has gain controls no need for the PVC. My outlaw amps don't have gain controls.
Have you ever tried turning up your panny XR55 to get the DCX input lights upto about -5?
Ah, so you are using the Panny as the prepro and then the EP2500 as the amp. Presumably you are just using the DCX for sub EQ then?
In that case you turn the attenuators on the EP2500 down and boost the LFE output as high as you can.
Panasonic XR55 ->---[LFE RCA OUT]--> DCX2496 ->--[XLR OUT]--> EP2500.
I was very curious to how others are running any decent signal from their consumer level receivers into the DCX2496. When I saw people were getting adequate signal in this thread I scratched my head and wondered as I'm not.
I'd be interested in knowing the input level they are seeing on the LED's as I am only getting -20 from my XR55.
As I understand, If you really want to make use of the 24 bit resolution, higher input is required. Our receivers just don't cut it.
Although it may "work" the noise floor is raised and you'll be introducing a TON of noise into the signal path as the low input is amplified.
I use my DCX as a crossover and so feed it from the main L-Rs of my prepro. I have balanced outputs but previously used it with RCAs. Then the DCX feeds my power amps which have gain controls on them.
I have the gain turned down on my power amps so that the input gains on the DCX hit the -20dB at low to average levels, the -10dB at highish levels and the-2dB at reference.
I have another DCX I've been using for bass EQ and it seldom gets above -20dB in normal listening, but will go all the way up for especially LFE intensive movies.
I turned up the volume on my NAD T-175 to max and did a test. I couldnt get the DCX input gains to hit anything past -10dB.
I have an Onkyo 885 and use the XLR outputs. It does give a higher output than the RCAs, but seem to recall that I was still able to get over -10dB with the single-ended outputs.
Yes, I have the 885 too so I will check it out this weekend. I bought several months ago just because it has XLR connections.
1 - 20 of 21 Posts
