Status
Not open for further replies.
1 - 5 of 5 Posts
Is it possible to run an external DVD player (Denon 2500) non progressive scan, into an HTPC and is it worth it?
How would one go about doing so?
I am asking because I thought I once saw a thread regarding somebody using their DVD player and DScaler with excellent results.
Thanx
Alun
Do a search for Holo3DGraph. If you can afford it ($850) it is the best thing currently going.
any Tuner or video input card with composit or, preferably, s-video in that is compatible with dscaler should let you get the video in, deinterlace and scale it. send the audio directly to your pre/pro or receiver. You might experiance audio sync problems however.
1 - 5 of 5 Posts
Status
