Using factory XM antenna with aftermarket unit on GM
777 Views 2 Replies 3 Participants Last post by  bendee
I have a 2003 Tahoe that came with XM radio. I replaced the factory system and would like to add XM to the replacement system, but I would like to use the factory antenna. Can this be done?
Status
Not open for further replies.
1 - 3 of 3 Posts
YES it can be done. Once you find the XM antenna cable, check the end to see if it will mate with your receiver and report back. A new end can be placed on the cable or an adapter can be added.
what system is it vgrubb?
1 - 3 of 3 Posts
Status
