Hello,
I was not sure where to post this question, so if this is not the correct place, please point me in the right direction. Next, I will try and explain best I can but if it does not make any sense, just let me know.
Few years ago, I built a wall to hold the cable box, dvd, etc. and it also went just over the top of a huge 60inch Sony rear projector tv. Looking at the 1st pic...take away the 2x4's that are showing...and that big hole is where the tv went.
About 2 months ago, I got a new Panasonic 65inch GT 30 Plasma. Looking at 2nd pic, you can see 2 pockets or holes, this is for the 3D DVD player and Xbox. Also, look past the studs, and you should be able to see that there is room to stand behind the wall once it is finished.
Pic 3...shows placement of tv ( still needs paint)...also look to the right of tv and there is a space between the wall and window. This is how I will get behind wall.
Now for the question:
I want to know if it would cause damage to either the tv or components, if I have a fan blowing on them, from behind the wall?
Example....under the dvd player, there is venting cut into the metal, so it can keep cool. And on the backside of the Panasonic tv, there are 2 big spots where the metal has venting....(Plasma's get HOT).
My idea....was to cut a small square out of the sheetrock....for each spot that had venting. Meaning, the pocket I made for the dvd player...I would cut out a small area of sheetrock under the unit, where the venting is on player. Same goes for the Plasma.
Then I would put a small 12inch or so fan, behind the wall, place it where the air from fan would hit the holes I cut.
I know components get hot and the plasma gets very hot. I dont see how this idea could hurt anything but you guys here, would know better then me.
Please take the time and let me know what you think. I dont have the experience that most of you have. You might think of a flaw in this design...all advice is welcomed.
Thanks in advance,
Mike
Thanks in advance,
Mike
