Okay, I started calibrating my TV using HCFR via DVI using the setting for rec709 & 16-235. Apparently the majority says that FW2.2 is still not doing the correct colorspace with DVI, so here's my question. Would you calibrate the DVI input with rec601 & 0-255 on it's own color temp setting? Then I could calibrate component with rec709 & 16-235 to a secondary color temp. Opinions, thoughts?
