Using PA subs for a midbass modules?
3440 Views 39 Replies 12 Participants Last post by  Red Five
I was thinking about it this morning and was saying how do I get more mid range punch out of my home theater subs. I though what about a Midbass module type sub then I though why not just get a PA style sub thats like 30-200hz should add all the extra punch I need.
Anyone on here using anything like this? Something like the 18" qsc https://www.sweetwater.com/store/de...rj4fS6FVjHQt4nfuCrc0SUDDU9Z7LBIYaArKVEALw_wcB
Seems to go 32-240hz that should be fine I think. Or did I miss something here?
1 - 20 of 40 Posts
There were many people using the Behrinher 1200D for midbass duty, I forgot which thread it was. Probably the tactile response thread.
Oh cool. I was looking at passives ones so i dont need to run rca i have 4 unused lines and some dsp amps doing nothing. I just saw the diy titan modules those are pretty cheap in comparison...or i could just get better subs?
Get a couple of the PA460's while PE has their Labor Day sale - prob $90 each, 4 cf. tuned to 30hz I think is what some have been doing for mid-bass with those. Or the buyout B-52s.
  • Like
Reactions: 1
Here:
https://www.avsforum.com/forum/113-...-mbm-increased-mid-bass-tactile-response.html
  • Like
Reactions: 1
I read through (a little) of that TR thread and it stated that there is more TR near port tune..... I’m looking at building pa cabinets also for a 60-150hz purpose which makes me question the 30hz tune. Wouldn’t you want to increase the port tune (if box size doesn’t matter) to a more respectable number like say 45hz for MAXIMUM TR? I know by doing this you create a higher peak in frequency response rather than a smoother flatter response but what are the exact trade offs? Especially if max TR between 60-200 is the goal.
2
I'm still waiting to see the weird looking in-room response curve in REW from some of you guys who love midbass.
I expect it looks something like what I drew below??
See less See more
  • Like
Reactions: 3
Seeing as that type of response curve is easy to achieve with any sub I've ever had, I can only assume it's even more extreme... :confused:
The trick is having it nearfield so you can feel the tr.
And it's usually set up out of phase so that it doesn't affect the fr.
And/or go with some variation of the BOSS:
https://www.avsforum.com/forum/19-d...gn-construction/2991522-hideaway-theater.html
  • Like
Reactions: 1
I agree... I just wanna see how un-flat their curves are. Most people strive for some sort of flatness... with maybe a house curve, sloping up to the left.
Or what about I just add 5 more 18s ? instead of the mid bass drivers
That HST-18 MKIII sale is rather tempting...Kinda pricy still 3k for 6 is money I Kinda rather spend that on a new 4k projector and AV
I'm still waiting to see the weird looking in-room response curve in REW ]
I think (as an amateur) TR and spl is NOT a direct comparsion. I think it is more of a conversation of utilizing the full potential of said driver to run inside its passband to achieve its full potiential.
Ever been to an outdoor concert where you can feel the kick drum from across the street? Giant concert venues use the best equipment to achieve the best results while staying within a flat response.
So, why would you use a ultimax to play midbass and why would you use a pa to play ulf? Answer: you wouldn’t.
To me this would be just utilizing the proper speakers to the best of their ability, NOT trying to boost the frequency to achieve a desired result.
Or am I wrong?
If you are not looking for higher frequency response this might not be it. I was playing with a Devastator MBM using the LaVoce SAF184.03. If the determination is TR is from particle velocity this has a HH tuned around 30Hz and then the front horn is tuned around 70Hz or so which has a particle velocity.
See less See more
Okay, now we’re talking. Would this work with the pa460? And what size box are we talking about? Looks like this will play from 30 to 200? So, if I couple this with my dual f20’s at about 60hz this should probably blend in quite well (for a horn) and still be able to play up to my HTM12’s with plenty of overhead. I’d like to know more.... I do like TR and overhead in the same sentence.
Yes the cabinet would work with a PA 460. I forgot the exact dimensions, I think it is 43x21x30. Power handling on the 460 is less. I will dig up more info when I get a chance again. It should be easy to integrate using a MiniDSP or a DSP amp.
Those are the big dogs, the MBM Devastator has not been put out there as a design yet :)
I was thinking about pairing the Dev MBM with a different design I was working on. This also is not out there, I call it the LBM (low bass module). I have a sim I like better than this one though for doing pretty much the same thing. This box uses a UM18.
See less See more
I found the box shot with dimensions. Depending on how nap time goes tomorrow I might have time to sim the PA460.
See less See more
21” is perfect. 30” doesn’t work (it’s the reason why I moved my f20’s) but I have up to 60 something inches to stretch this to so.... can we shrink the 30” to a more manageable size? I’m going to lay these down and put my htm’s on them for the RL. Let me know what you come up with, and if it’s a more manageable size for me I’m in.
Room Loudspeaker Property Audio equipment Electronics
See less See more
What's your max depth and the max you can go up on the tune? I still have to fit the sub and make the vent hit a power target with air velocity not going to heck. It can get taller, it's just a less elegant box since the length of the front determines the peak of the upper response. It ends up being a box with a cubby over the front chamber if the resonator is shorter than the box dimensions dictate. The longer the resonator gets, the peak appears lower in the response. This is a 95cm resonator, Dev v1 is 110cm and BMD is 140cm ish. If the box gets wider the front resonator gets shallower, along with the box in general.
1 - 20 of 40 Posts
