Status
Not open for further replies.
1 - 2 of 2 Posts
My room is 17 x 20 and on the end with the racks and screen I want to use receccess lighting to wash the wall with light. I was either planning on 9 lights or 7 in the following configuration. I know I want the front lights ~ 3 ft apart but how far from the screen wall do I want them?
Wall
3.5ft
O O O
5ft
0 0
5ft
0 0
3.5ft
Wall
or
Wall
6"
0 0 0 Very small under cabinet lights
3'000000
0 0
5'
0 0
5'
0 0
3.5'
Wall
So the question is how far away from the screen wall are you putting your lights to wash the screen? I know I probably want them three ft apart just not sure how far away from the screen wall.
RETIRED theater builder
Here is a pretty detailed on-line layout guide from one of the manufactures of recessed lighting.
http://www.lithonia.com/ResidentialL...ayoutGuide.pdf
For wall wash they say 3 ft, for wall graze they say 9 inches.
Also food for thought. I discovered this when planning lights for an "art studio". If you want even light distribution in a room at floor level. The cans on the perimeter should be about 1/2 the distance from the wall as they are spaced apart. This avoids relatively darker areas around the perimeter.
1 - 2 of 2 Posts
Status
