Now Available: Tech Talk Podcast with Scott Wilkinson, Episode 19 Click here for details.
Originally posted by collin what would be *very* interesting would be to hack the Linksys NSLU2 network storage device into running a DVArchive server, so we could watch from networked RTVs or PCs without running a PC all the time. Even more interesting would be to get WiRNS up on this thing. Introduction to hacking this thing: http://www.tomsnetworking.com/Sectio...le85-page1.php |
Originally posted by icecow It would be a great place to keep confidential files if you believe in security by obscurity. |
Originally posted by icecow you can change the extention of a file to .jpg and move it on to the replaytv. It would be a great place to keep confidential files if you believe in security by obscurity. |
Originally posted by DanV Does it crash or lock up the Replay if you try to view one of those non-.jpg files? |
Originally posted by hilbert1862 hey cow, yer PM bin is full! |
Originally posted by j.m. I don't think it is feasible to run DVArchive on the NSLU2. Among other reasons, it only has 32MB RAM, which is the minimum required by Java. |
Originally posted by Jeff D I had PM'd Gerry if DVA could allow files with other extensions to be sent, but I never got a response back. |
Originally posted by collin i should have been a bit clearer...obviously running the full DVA would be too much for this type of box, but I was thinking that if a subset of DVA-type functionality that just contained the serve-up-these-files portion could be coded (not in java), that setup would be much preferable to running a PC all the time. another portion that might be useful would be the web-programming interface, for the same reasons. |
Originally posted by WannabeSQ If i'm not mistaken, couldn't someone get a NAS device, and run DVA on a regular computer, or perhaps a lite linux box, and simply map the storage of DVA to the networked drive? Then adding storage is simple, get the NAS boxes, and just add them to DVA's list of drives. |
Originally posted by BaysideBas Gerry, there's a switch in your forum profile that, when enabled, will notify you by email that there's a PM awaiting you. The email even includes a link to make it easier to pick up your mail. As to PM box being full, it's just an oversight in the application running it. Apparently it notifies you of a full inbox when it can't accept any more messages, not when it receives the last possible message, or even when it's approaching a full status. |
Originally posted by BaysideBas All too common if you ask. |
