In a previous thread, ROBMARK said the following:
(See attached picture of Robert's soffit)
Question: I am in the same boat as Robert as my soffit is not big enough to run the flexduct as originally planned. If I use the same technique as Robert, do I need to be concerned about isolating the inside of the soffit? Besides noise, I'm more concerned about condensation forming and over time causing damage to the ceiling drywall/soffit.
--curtis
You had asked for a pic of the soffit/air supply. The original plans called for the ductwork to run within the soffit, but due to size limitations, that was changed. What I did was have the duct boxes mounted in the drywall as if they were going to place the grills in the drywall. I then constructed the soffits, and once the bottom of the soffits are in place, I will attach the grills directly to the MDF. Robert |
--curtis
