Status
Not open for further replies.
1 - 2 of 2 Posts
I just hooked up the Terk TV42 to my DTC-100. This is the OTA antenna that clamps onto the dish. I hope I have it wired correctly. I am running from the output of the 4X4 multi-switcher to an input on the antenna. From the antenna, I run the cable (RG-6) into the house. At the rear of the IRD, I have a diplexer going into both antenna A, and SAT IN. I am getting a signal of low 90s on the 101 bird and low 70s on the 119 bird. For me, that is acceptable. Only after jiggling the antenna, do I get a signal on the local HD channels, only briefly (a second or two). But, for the most part, I don't get any signal from the locals (analog or digital) at all. I plugged my cable TV cable into Antenna B, and I don't get anything from there (yes, I have the cable bubble highlighted in the menu for) at all. Do I need another diplexer outside? Does anyone have this set up at all? Is Terk that bad an antenna?
The Terk is a POS. Search the forum and post about OTA recption in your area. Stay away from anything that has Terk on it. IMO. End of Rant!
Dave
BTW Welcome to AVS!
Watch HDTV!!! Nothing else comes close!
[This message has been edited by David Richardson (edited 06-27-2001).]
1 - 2 of 2 Posts
Status
