Status
Not open for further replies.
1 - 4 of 4 Posts
those of you that have this player are you using the dvi cable that came with it, or did you purchase an aftermarket one?
I use the supplied cable.
I have had no problems at all (not even with audio syn) hooked up to my Sammy DLP!!
Good luck!
Use the cable that comes with it...I have a high end cable from Ram and the cable that came with the unit and there is know difference in video performance...save your money.
1 - 4 of 4 Posts
Status
