Status
Not open for further replies.
1 - 1 of 1 Posts
I have connected a VGA to Component Transcoder (Crescendo) between my HTPC and my receiver so I can use the receiver as a component video switch.
The VT440 will take VGA or component signal via a vga cable.
The problem I am having is it seems the project identifies the component signal coming out of the transcoder as vga when it is on auto signal identification and as such the picture comes out green.
If I set the input to component the project says no signal
I thinks the problem I have is that the resolution and frequency I am feeding the transcoder is causing the problem (800x600 75hz)
I live in Pal land and the projector has a native resolution of 800x600.
Could anyone suggest a passible fix for my problem?
1 - 1 of 1 Posts
Status
