Status
Not open for further replies.
1 - 4 of 4 Posts
I'm getting a DC-2 and a couple of Parasound amps. To use the triggers do I basically run wires from the DC2 to the triggers on the amps (to the respective points). Is it that easy?
Pretty much. You have 12 volt triggers on your DC-2, if the parasound amp have matchig 12volt triggers its that simple. Hopefully some parasound owners will chime in.
I added a panamax 1000+ to switch my amps and other gear on and off. You can find them new and online for $150 ea.
The DC-2 has a bare wire terminal block, so you may have to strip a wire depending on what cable you have (I actually had a Parasound preamp before my DC-2, which has a miniplug connector for the trigger) but it's pretty simple. There's a "pgm" lead and you can go into the DC-2 setup menus and activate the trigger for various sources. If I recall correctly the default is off, so make sure to check out the input config menu.
1 - 4 of 4 Posts
Status
