... I had the sub set up with the LFE and had to turn it up almost all the way to get the slightest bass out of it. Maybe I set it up wrong ...
1. Do a sub crawl and find the best location in which to place your sub.
2. Turn the gain on your sub to "12:00".
3. Run the first cycle of Audyssey and check the sub level in your AVR's speaker-set up menu.
4. If the sub level is too low (relative to the speakers), lower the gain on the sub; if the sub level is too high (relative to the speakers), raise the gain on the sub.
5. Repeat #3 and #4 as required until the sub level is close to the level of the speakers.
6. Run the full set of Audyssey cycles.
7. Go into the speaker set-up menu and set all speakers to "small".
8. If necessary, adjust the crossover settings.
9. Tweak levels if required / as desired.
10. Enjoy.
