UST Projector Questions and Clarifications
1037 Views 4 Replies 2 Participants Last post by  fornent
I have a support beam that protrudes several inches from the ceiling about halfway through the length of my intended home theater room. My assumption is a short throw projector will be my best solution here to avoid having to work around the potential headaches a longer throw projector would have with trying to fully project past the beam (this could be incorrect).
Regardless, looking at the Optoma CinemaX P2 as a possible option. Couple of questions on this particular projector:
1. I was wanting a screen larger than what the specs say are supported (120" diagonal at 16:9). Is there anyway to project on a larger screen with a UST projector (even if there is loss in image quality).
2. Is there any drawback to ceiling mounting this projector?
3. The specific screen I was considering matching up with this was a SeymourAV with a constant area aspect ratio (2.07). Is it easy to use the zoom functionality when attempting to maximize the height/width of an image for given aspect ratio?
Thanks ahead of time for anyone's answers.
1 - 5 of 5 Posts
Most projectors will have a slight downward throw when ceiling mounted and/or have some vertical lens shift to allow the projected image to clear the support beam. The projector ceiling mount typically drops the projector ~6in from the ceiling, and the lens centre is typically ~2in from the base of the projector. However, it really helps to have very precise measurements of intended screen location, wall, ceiling and screen height to make sure the installation will work as intended.
1) Many USTs have a limited focus range which will determine maximum image size. Optoma specs state 120in max for the P2.
2) I can't answer that.
3) USTs typically have no optical zoom.
Here's a projector image size calculator with a BenQ HT5550 used as a example:
(use the drop down menu at the top to select other projectors - always check manufacturer specs before buying)
Let's say that your ceiling beam drops down 6in, and is 8 ft from the screen wall. If you want the top edge of the screen to start 6in from the ceiling, then you could place the HT5550 anywhere in the room and have no problems with projected image clearing the beam. A higher top of screen might require the projector ceiling mount to be placed further from the ceiling to have the top edge of the image clear the beam.
Variable masking sounds great in theory, but there are some movies that use a variable aspect ratio within the same film...
A painted screen wall can work very well with long throw projectors.
See less See more
Thanks for the response @DunMunro. Sorry for the delayed reply. Could you elaborate on your comments about variable masking? Are you suggesting I just stick with a standard 16:9 or 2.39:1 ratio screen?
IMHO, it's best to use the largest possible screen that matches the native format of your projector.
Makes sense. Thanks for the clarification.
1 - 5 of 5 Posts
