Status
Not open for further replies.
1 - 5 of 5 Posts
· Registered
having a problem with PIP on my Sony UTV: I can't move the PIP window anymore (using "enter" button on remote).
Problem seemed to coincide with 3.5 update but could be completely unrelated.
Confirmed that "enter" keys works in all other capacities.
Anyone else had this problem? Suggestions?
· Registered
What about using CMD-M on the keyboard. (This works for RCA's, I assume it works on Sony too?). Just trying to confirm the problem is with the remote (physical or logical problem) and not with the UTV PIP function itself.
· Registered
It's definitely a 3.5 upgrade issue. I noticed it the same day it came out. I am guessing it has something to do with the "unmarrying" of the Sony and RCA remotes, since the RCA doesn't have the corresponding key on the remote.
· Registered
Me too, and now it means that I have to program some other button on my universal remote when enter worked great for me before. I also wish it worked like the RCAs where when you're in the guide, channel +/- went page-at-at-time instead of the stupid scroll buttons.
1 - 5 of 5 Posts
Status
