1 - 5 of 5 Posts
Discussion Starter #1
My InFusion system started to behave funny since the last few months - the sound from the keypads would randomly changed its tone when the key is pressed, and some of the IR zones would stop reacting to received commands.
I have tried using Monitor Key Press to make sure IR signal is received, and it is but nothing happens.
It will take a re-download of the same configuration to the controller to truly fix it. If I simply power cycle the Infusion controller, the keypad sounds may go back to normal but the IR zones never restore.
Anyone had similar experience? Trying to diagnose if this is a hardware or software problem...
1 - 5 of 5 Posts
