I can't speak to comparisons between the units themselves, as I've never used any besides the Audio Authority 9A60 RGB->component transcoder, but...
I've had an old PC hooked up via this device to a Sony KP HS30 for a year now and it works well enough for games and graphics. Never used it for DVD viewing. Text is crummy, though, and using the setup for text-based applications is not practical. Much of this may have to do (and likely does) with the output resolution of my video card not matching the native lines of resolution on the Sony, and not the 9A60 unit itself.
I tried various second hand video cards, but couldn't get satisfaction with the Sony set in conjunction with the Nvidia drivers/chipsets (they would lock up my machine at that time)... YMMV, but don't expect text to be useable based upon what I have seen with the Audio Authority device. For text based applications I'm of the opinion that you have got to perfectly match the output resolution from the video card with the native lines of resolution on your digital TV (or other component display device). Then it might just work for you...
I would guess (only speculatively) that the relative picture might be measurably better on a smaller set...
