Status
Not open for further replies.
1 - 7 of 7 Posts
Question, I have a new JVC SVHS vcr hooked upto my 1272 via line doubler.
Picture looks fantastic, but on the top 1/4 of the screen, the tape always jitters up & down, like it needs tracking. The remainder of the picture is fine. Screen is a 100" 4:3
The vcr has auto tracking so I can't adjust it. All tapes have the same problem.
Is this the vcr's fault? Or is it something because of the large screen size?
check it with another tv
XANATOS
Premium Member
I used to run my VCR through a DVDO line doubler and had the same problem. If you search the forum, you'll find that you need a different VCR that has a more stable output. It's a trade name and I can't remember the name of the feature. Several manufacturers offer it. I ended up with a JVC and it fixed the problem. Apparently the unstable syncs from a standard VCR give the line-doubler fits.
Cary
There used to be some pretty inexpensive S-VHS JVC's with time-base correctors in them. Might be able to find a decent one on ebay.
I think you'll need a VCR with a TBC or an out-board TBC. I had the same problems capturing VHS on the computer until I got the JVC with TBC.
Good luck.
SC
Hook your iScan to your computer monitor.
The Iscan does not do well with jitter from a vcr. I have a JVC with a timebase corrector, no more problem.
Marc
1 - 7 of 7 Posts
Status
