Hello!
I'm not sure this is the right subforum, but I couldn't find anything on retro/vcr video equipment anywhere else =/
Anyway, I have an old Sony SLV-940HF VCR/Recorder that had a tape jammed in it. It wouldn't play, eject, or anything. So I had to open it up, and carefully remove the tape manually. When I put everything back together, I noticed it will no longer "take" the tape when I put it in. Usually it sucks it in and does it thing, but it won't do anything now!!
I've checked the "tape loading bracket" and mechanically it works fine. I put the tape in and can manually slide it back and down. But for some reason, the VCR it won't automatically feed. Also, the VCR itself seems to work fine. Everything is spinning and moving, etc.
Here are some pics. I'd really appreciate some help
http://img94.imageshack.us/img94/3784/dscn3177a.jpg
http://img842.imageshack.us/img842/9989/dscn3179k.jpg
http://img846.imageshack.us/img846/2804/dscn3178.jpg
thanks!!
thanks!!
