Status
Not open for further replies.
1 - 3 of 3 Posts
· Registered
Is anyone using this transcoder sucessfully with a Comcast STB? If you are can you tell me the dip switch settings you are using. I have one, but am not able to get it to give me the correct horizontal settings or color. I'm having the same issue on a 15" moniter and a FP Barco CRT.
· Registered
Bill-
I suspect that the device's output does not remove the sync from the "Y" (now "G") output pin. I sent a message to the company to ask about it.
1 - 3 of 3 Posts
Status
