1 - 1 of 1 Posts
1 owner, bought new. Kit with Mic, Cable, Remote
$4500 new
Most recent firmware 2.2.2
• Built-in 1250 watt (RMS), 3,000 watt peak power high-efficiency Class-D amplifier
• Tandem 3” voice coil
• Multi-layer resin laminate cone
• High-excursion rubber surround
• Gain compression, anti-clipping circuit to prevent over excursion and amp clipping
• Fixed 80Hz high-pass crossover (RCA output)
• Balanced (XLR) input
• Line-level (RCA) inputs and thruputs
• Speaker-level inputs
• Variable volume control
• Frequency response of 20Hz - 120Hz +/-3dB
• Detachable 6-foot AC power cord
• Four rubber 1/4 --20 threaded support feet (aluminum with rubber inserts on 15” and 18” models)
• On-screen controls:
- Auto-eQ/Self-eQ
- Graphic or Parametric Equalizer controls for room EQ
- Adjustable (15Hz - 199Hz) low-pass crossover (defeatable)
- multiple staggered low pass crossovers (6dB/octave, initial to 36dB/octave, ultimate)
- Adjustable (15Hz - 35Hz) subsonic filter (defeatable)
- Multiple staggered subsonic filters (12dB/octave, initial to 24dB/octave, ultimate)
- Variable volume control
- Adjustable phase control (0° - 180° in 15° increments)
- Selectable polarity (+/
- Theater/music selection indicator (servo gain control)
- Signal sensing auto turn on/off/12 Volt trigger (defeatable)
- 6 presets for customized listening modes and eQ defeat
- Selectable default preset
- Switchable Velodyne logo indicator
- night mode maximum volume setting
- Save settings indicator
- daisy chain feature
1 - 1 of 1 Posts
