1 - 6 of 6 Posts
Discussion Starter #1
Just wondering if this sub can be controlled with the Harmony Ultimate.Mine don’t seem to work with the harmony software but all my other sources do.I can control my blurry player, processor,projector,Xbox but not my dd15+. I have codes but have no idea what to do with them.:frown::confused:
Just wondering if this sub can be controlled with the Harmony Ultimate.Mine don’️t seem to work with the harmony software but all my other sources do.I can control my blurry player, processor,projector,Xbox but not my dd15+. I have codes but have no idea what to do with them.
/forum/images/smilies/confused.gif
Is it a learnable remote?
My DDs (not +) and RELs are setup on the Universal remote and is great.
Discussion Starter #3
Yea my Harmony Ultimate learns the commands by pointing the Velodyne remote at the Harmony remote and holding down the buttons and then the software indicates it has been learnt with a green tick,but when pressing the “power on” button on the harmony remote nothing happens.
Is there any trouble shooting in the manual.
There is a code for the Velodyne DD+?
How old is the remote?
I remember with mine couple of functions wouldn't work but wasn't needed anyway, but definitely need power.
Mine is 15+ years old.
Discussion Starter #5
My Velodyne remote is 9 years old as is the subwoofer. The velodyne remote does work well and is responsive though.I have a bunch of codes which i downloaded
. 0000 006D 0009 0009 0008 0027 0008 0046 0008 001D 0008 006A 0008 0046 0008 001D 0008 0037 0008 0022 0008 0BE7 0008 0027 0008 001D 0008 001D 0008 006A 0008 0046 0008 0046 0008 0037 0008 0022 0008 0BE7
0 0000 006D 0012 0000 0008 0027 0008 003C 0008 001D 0008 006A 0008 0046 0008 001D 0008 0037 0008 002C 0008 0BE7 0008 0027 0008 0065 0008 001D 0008 006A 0008 0046 0008 0046 0008 0037 0008 002C 0008 C760
1 0000 006D 0012 0000 0008 0027 0008 0060 0008 001D 0008 006A 0008 0046 0008 001D 0008 001D 0008 0022 0008 0BE7 0008 0027 0008 0037 0008 001D 0008 006A 0008 0046 0008 0046 0008 001D 0008 0022 0008 C760
2 0000 006D 0012 0000 0008 0027 0008 005B 0008 001D 0008 006A 0008 0046 0008 001D 0008 001D 0008 0027 0008 0BE7 0008 0027 0008 0031 0008 001D 0008 006A 0008 0046 0008 0046 0008 001D 0008 0027 0008 C760
3 0000 006D 0012 0000 0008 0027 0008 0056 0008 001D 0008 006A 0008 0046 0008 001D 0008 001D 0008 002C 0008 0BE7 0008 0027 0008 002C 0008 001D 0008 006A 0008 0046 0008 0046 0008 001D 0008 002C 0008 C760
4 0000 006D 0012 0000 0008 0027 0008 0050 0008 001D 0008 006A 0008 0046 0008 001D 0008 001D 0008 0031 0008 0BE7 0008 0027 0008 0027 0008 001D 0008 006A 0008 0046 0008 0046 0008 001D 0008 0031 0008 C760
5 0000 006D 0012 0000 0008 0027 0008 004B 0008 001D 0008 006A 0008 0046 0008 001D 0008 001D 0008 0037 0008 0BE7 0008 0027 0008 0022 0008 001D 0008 006A 0008 0046 0008 0046 0008 001D 0008 0037 0008 C760
6 0000 006D 0012 0000 0008 0027 0008 006A 0008 001D 0008 006A 0008 0046 0008 001D 0008 003C 0008 004B 0008 0BE7 0008 0027 0008 0041 0008 001D 0008 006A 0008 0046 0008 0046 0008 003C 0008 004B 0008 C760
7 0000 006D 0012 0000 0008 0027 0008 004B 0008 001D 0008 006A 0008 0046 0008 001D 0008 0037 0008 001D 0008 0BE7 0008 0027 0008 0022 0008 001D 0008 006A 0008 0046 0008 0046 0008 0037 0008 001D 0008 C760
8 0000 006D 0012 0000 0008 0027 0008 0041 0008 001D 0008 006A 0008 0046 0008 001D 0008 0037 0008 0027 0008 0BE7 0008 0027 0008 006A 0008 001D 0008 006A 0008 0046 0008 0046 0008 0037 0008 0027 0008 C760
9 0000 006D 0012 0000 0008 0027 0008 0037 0008 001D 0008 006A 0008 0046 0008 001D 0008 0037 0008 0031 0008 0BE7 0008 0027 0008 0060 0008 001D 0008 006A 0008 0046 0008 0046 0008 0037 0008 0031 0008 C760
Down arrow 0000 006D 0009 0009 0008 0027 0008 0050 0008 001D 0008 006A 0008 0046 0008 001D 0008 0027 0008 0027 0008 0BE8 0008 0027 0008 0027 0008 001D 0008 006A 0008 0046 0008 0046 0008 0027 0008 0027 0008 0BE8
Up arrow 0000 006D 0009 0009 0008 0027 0008 0056 0008 001D 0008 006A 0008 0046 0008 001D 0008 0027 0008 0022 0008 0BE8 0008 0027 0008 002C 0008 001D 0008 006A 0008 0046 0008 0046 0008 0027 0008 0022 0008 0BE8
Left arrow 0000 006D 0012 0000 0008 0027 0008 004B 0008 001D 0008 006A 0008 0046 0008 001D 0008 0027 0008 002C 0008 0BE7 0008 0027 0008 0022 0008 001D 0008 006A 0008 0046 0008 0046 0008 0027 0008 002C 0008 C760
Right arrow 0000 006D 0012 0000 0008 0027 0008 0046 0008 001D 0008 006A 0008 0046 0008 001D 0008 0027 0008 0031 0008 0BE7 0008 0027 0008 001D 0008 001D 0008 006A 0008 0046 0008 0046 0008 0027 0008 0031 0008 C760
Select 0000 006D 0012 0000 0008 0027 0008 0041 0008 001D 0008 006A 0008 0046 0008 001D 0008 0027 0008 0037 0008 0BE7 0008 0027 0008 006A 0008 001D 0008 006A 0008 0046 0008 0046 0008 0027 0008 0037 0008 C760
Light 0000 006D 0009 0009 0008 0027 0008 0027 0008 001D 0008 006A 0008 0046 0008 001D 0008 001D 0008 005B 0008 0BE7 0008 0027 0008 0050 0008 001D 0008 006A 0008 0046 0008 0046 0008 001D 0008 005B 0008 0BE7
Light On 0000 006C 0009 0009 0008 0027 0008 0057 0008 001D 0008 006C 0008 0047 0008 001D 0008 0037 0008 0067 0008 0BFD 0008 0027 0008 002D 0008 001D 0008 006C 0008 0047 0008 0047 0008 0037 0008 0067 0008 0BFD
Light Off 0000 006C 0009 0009 0008 0027 0008 0047 0008 001D 0008 006C 0008 0047 0008 001D 0008 003C 0008 001D 0008 0BFD 0008 0027 0008 001D 0008 001D 0008 006C 0008 0047 0008 0047 0008 003C 0008 001D 0008 0BFD
Mute 0000 006D 0009 0009 0008 0027 0008 0031 0008 001D 0008 006A 0008 0046 0008 001D 0008 0037 0008 0037 0008 0BE7 0008 0027 0008 005B 0008 001D 0008 006A 0008 0046 0008 0046 0008 0037 0008 0037 0008 0BE7
Mute On 0000 006C 0009 0009 0008 0027 0008 0042 0008 001D 0008 006C 0008 0047 0008 001D 0008 003C 0008 0022 0008 0BFD 0008 0027 0008 006C 0008 001D 0008 006C 0008 0047 0008 0047 0008 003C 0008 0022 0008 0BFD
Mute Off 0000 006C 0009 0009 0008 0027 0008 0037 0008 001D 0008 006C 0008 0047 0008 001D 0008 003C 0008 002D 0008 0BFD 0008 0027 0008 0061 0008 001D 0008 006C 0008 0047 0008 0047 0008 003C 0008 002D 0008 0BFD
Night 0000 006D 0012 0000 0008 0027 0008 002C 0008 001D 0008 006A 0008 0046 0008 001D 0008 0037 0008 003C 0008 0BE7 0008 0027 0008 0056 0008 001D 0008 006A 0008 0046 0008 0046 0008 0037 0008 003C 0008 C760
Night On 0000 006C 0009 0009 0008 0027 0008 005C 0008 001D 0008 006C 0008 0047 0008 001D 0008 0037 0008 0061 0008 0BFD 0008 0027 0008 0032 0008 001D 0008 006C 0008 0047 0008 0047 0008 0037 0008 0061 0008 0BFD
Night Off 0000 006C 0012 0000 0008 0027 0008 0052 0008 001D 0008 006C 0008 0047 0008 001D 0008 0037 0008 006C 0008 0BFD 0008 0027 0008 0027 0008 001D 0008 006C 0008 0047 0008 0047 0008 0037 0008 006C 0008 C938
Power 0000 006D 0012 0000 0008 0027 0008 006A 0008 001D 0008 006A 0008 0046 0008 001D 0008 001D 0008 006A 0008 0BE7 0008 0027 0008 0041 0008 001D 0008 006A 0008 0046 0008 0046 0008 001D 0008 006A 0008 C760
Power On 0000 006C 0009 0009 0008 0027 0008 003C 0008 001D 0008 006C 0008 0047 0008 001D 0008 003C 0008 0027 0008 0BFD 0008 0027 0008 0067 0008 001D 0008 006C 0008 0047 0008 0047 0008 003C 0008 0027 0008 0BFD
Power Off 0000 006C 0009 0009 0008 0027 0008 0032 0008 001D 0008 006C 0008 0047 0008 001D 0008 003C 0008 0032 0008 0BFD 0008 0027 0008 005C 0008 001D 0008 006C 0008 0047 0008 0047 0008 003C 0008 0032 0008 0BFD
Preset 1 0000 006D 0009 0009 0008 0027 0008 0027 0008 001D 0008 006A 0008 0046 0008 001D 0008 0037 0008 0041 0008 0BE7 0008 0027 0008 0050 0008 001D 0008 006A 0008 0046 0008 0046 0008 0037 0008 0041 0008 0BE7
Preset 2 0000 006D 0009 0009 0008 0027 0008 0060 0008 001D 0008 006A 0008 0046 0008 001D 0008 0022 0008 001D 0008 0BE7 0008 0027 0008 0037 0008 001D 0008 006A 0008 0046 0008 0046 0008 0022 0008 001D 0008 0BE7
Preset 3 0000 006D 0012 0000 0008 0027 0008 0065 0008 001D 0008 006A 0008 0046 0008 001D 0008 0037 0008 0056 0008 0BE7 0008 0027 0008 003C 0008 001D 0008 006A 0008 0046 0008 0046 0008 0037 0008 0056 0008 C760
Preset 4 0000 006D 0012 0000 0008 0027 0008 0022 0008 001D 0008 006A 0008 0046 0008 001D 0008 0037 0008 0046 0008 0BE7 0008 0027 0008 004B 0008 001D 0008 006A 0008 0046 0008 0046 0008 0037 0008 0046 0008 C760
Preset 5 0000 006D 0012 0000 0008 0027 0008 005B 0008 001D 0008 006A 0008 0046 0008 001D 0008 0022 0008 0022 0008 0BE7 0008 0027 0008 0031 0008 001D 0008 006A 0008 0046 0008 0046 0008 0022 0008 0022 0008 C760
Preset 6 0000 006D 0012 0000 0008 0027 0008 0060 0008 001D 0008 006A 0008 0046 0008 001D 0008 0037 0008 005B 0008 0BE7 0008 0027 0008 0037 0008 001D 0008 006A 0008 0046 0008 0046 0008 0037 0008 005B 0008 C760
Reset 0000 006D 0009 0009 0008 0027 0008 003C 0008 001D 0008 006A 0008 0046 0008 001D 0008 0027 0008 003C 0008 0BE7 0008 0027 0008 0065 0008 001D 0008 006A 0008 0046 0008 0046 0008 0027 0008 003C 0008 0BE7
Test 0000 006D 0012 0000 0008 0027 0008 0037 0008 001D 0008 006A 0008 0046 0008 001D 0008 0027 0008 0041 0008 0BE7 0008 0027 0008 0060 0008 001D 0008 006A 0008 0046 0008 0046 0008 0027 0008 0041 0008 C760
Menu 0000 006D 0012 0000 0008 0027 0008 005B 0008 001D 0008 006A 0008 0046 0008 001D 0008 0027 0008 001D 0008 0BE7 0008 0027 0008 0031 0008 001D 0008 006A 0008 0046 0008 0046 0008 0027 0008 001D 0008 C760
Exit 0000 006D 0012 0000 0008 0027 0008 0031 0008 001D 0008 006A 0008 0046 0008 001D 0008 0027 0008 0046 0008 0BE7 0008 0027 0008 005B 0008 001D 0008 006A 0008 0046 0008 0046 0008 0027 0008 0046 0008 C760
Vol + 0000 006D 0012 0000 0008 0027 0008 0022 0008 001D 0008 006A 0008 0046 0008 001D 0008 001D 0008 0060 0008 0BE7 0008 0027 0008 004B 0008 001D 0008 006A 0008 0046 0008 0046 0008 001D 0008 0060 0008 C760
Vol - 0000 006D 0012 0000 0008 0027 0008 001D 0008 001D 0008 006A 0008 0046 0008 001D 0008 001D 0008 0065 0008 0BE7 0008 0027 0008 0046 0008 001D 0008 006A 0008 0046 0008 0046 0008 001D 0008 0065 0008 C760
Ok, which one is for the Velodyne DD+.
In the manual does it list what equipment these codes are for. Sounds crazy that these are listed with no reference.
Contact Harmony and if no support contact Velodyne. They have changed ownership.
1 - 6 of 6 Posts
