Sorry for some reason it double posted, can't find place to delete it. If Mod could remove double post?
Yes I have followed I think every build thread. Just my restricted demension's make port and everything different? JB build works if I can put driver on 22 inch side, but make it 20 instead. Don't know how to model changes. Anything works for me with port and driver on 20 inch side. I have wall on one side and screen on the other with electronics under it. So I didn't think I wanted port or driver firing into electronics cabinet?Quote:
Originally Posted by steve nn /t/1517818/vented-sub-box-design-help#post_24358576
Here are two projects that you might be interested in? The first one started as a two driver option X2 but then turned into a quad. See what you think and then we can work from there. Here is another link that might be of use to you also. http://www.avsforum.com/t/1516043/my-ported-uxl-18-in-9-9cf-x2
http://www.avsforum.com/t/1506201/unnamed-sub-build
Originally Posted by BrentTHX /t/1517818/vented-sub-box-design-help#post_24359300
Sounds good!! 4 of them should hammer pretty good? Room is 3000 CF plus or minus a little. 14' wide X 25' 9" X 8'3". Is it a good idea to put them one in each corner? The front and back ones would fire towards each other. By two slot vent you me one vent with a divider/brace in middle splitting it in half? Sorry for all the newbe questions. Have done a ton of subs for cars but everyone has been sealed. And always had manufacture telling me box size for what I wanted it to sound like.
What linc? the earlier ones? or is there another? OK I will figure out vent, I think i know what you mean. I take the area that the vent uses up so it gets subtracted from the box volume?Quote:
Originally Posted by steve nn /t/1517818/vented-sub-box-design-help#post_24359546
You never know what works out best for sub placement but you'll have plenty to work with that's for sure. Try each corner to start out and work from there. Yes one 3/4 divider down the middle. I tried to go three slots but it didn't work out. It would of helped you for bracing purposes but we you can work around it, it's not very wide so you're good.
Ok this is what I would like you to do. Go to the link I provided and figure how much volume your vent is going to take up. Minus 1.5" off the length of your vent when factoring. EDIT> Factor in the 3/4 ply also as part of your vent. Lets plan on incorporating 1" dowel to save space and weight (if that works for you) but in no way effecting the integrity of your enclosure. If you like factor in the driver also and I'll factor the bracing.
Thanks!!! I'm so lost on vented!! LOl Crazy part is my stereo in my car has to be worth 50 grand all built be myself, but when it comes to this I'm lost.Quote:
Originally Posted by steve nn /t/1517818/vented-sub-box-design-help#post_24360002
Sorry about that, looks like I had the same link posted twice or something. Use the brace calculator as a solid, very easy..
http://www.hometheatershack.com/forums/enclosure-volume-calculator/
Originally Posted by LTD02 /t/1517818/vented-sub-box-design-help#post_24360062
i think this is what steve is talking about, but i'm not 100% sure...
it would be really simple and perform great. single slot port running down the back and firing up. if that is a cool design for you, all you really need to do is pick a tuning frequency and the port length can be calculated.
I'm good with anything as long as foot print is 20 X 24 thats all that matters, it will be behind false Colum .I'm more worried about performance than anything.Quote:
