1 - 5 of 5 Posts
I have purchased a couple of prisms from surplus shed and originally had decided to do horizontal stretching but have read that vertical compression has fewer issues and produces a better image. Is this true? Also are there any good build threads that have used a vertical compression? Can it be done with prisms still? Thanks so much for any help/info!
VC lenses are still prism based. Panamorph has stated they prefer VC over HS lenses. Maybe barrel distortion is less offensive to pincushion. I believe it may have more to do with the fact that VC lenses are more useful with projector with limited throw ratios like 1.0-1.2 and at much longer throws, which, in and of itself, improves distortions.
The issue that comes to mind with using these prisms is that they are only about 75mm (3") high. When you turn these on their side to form a VC, there is now just 75mm (3") of width. So you will need a really long throw or you will get vignetting.
Yes, a VC need only have 2 singlet prisms where a HE really needs 2 Doublets plus a correction lens.
VCs exhibit barrel distortion, so a flat screen is best here.
1 - 5 of 5 Posts
