1 - 1 of 1 Posts
Hi
Is it possible to vertical shift the position of subtitles on bluray, I have tried to play around with FFDSHOW with no luck.
If it is possible what software do you use and how do you set it up?
I have seen that the feature have been implemented in the mediaplayers made by HDI DUNE, how is the picure quality compared to a HTPC?
This is really important to me, it will make my 2.35:1 Constant Image Height setup complete.
Best Regards
Chewie1
1 - 1 of 1 Posts
