Hi there... this is my first HTPC I'm trying to put together. I bought a radeon VE DDR that i'm trying to connect to my toshiba 65" HDTV.
i bought the audio authority vga-> component (y, pb, pr) converter and am trying to connect it that way.
using s-video out, i can use the computer at 800x600. however, when i try to switch to vga out on the video card and use the vga-> component converter, i get to see the boot process but then the screen turns to garbage and then blank after it tries to get into windows.
i can't seem to find instructions on how to do this anywhere. can someone please point me kindly in the right direction? do i need special drivers or do i need to set the vga converter to something first? what resolution and refresh rate should the computer be set to use?
thanks.
thanks.
