Status
Not open for further replies.
1 - 2 of 2 Posts
I need a new video distribution box for my church. This is a VGA connector device.
They have an Extron DA-4 now, but is seemly not compatible with the new Mitsubishi X500 projector. It randomly goes to "no signal" when the projector thinks there is no signal any longer.
Please recommend an alternative unit please.
I need to have this fixed by next Friday.
Markertek has some equipment that might fit your needs. I have the Kramer VP300, which just does a a 1 to 3 split. If you need to boost voltages or invert, you may need to go with some of the other Extron units (I forget the model numbers right now, but you can search for Extron in the CRT forum).
Al
1 - 2 of 2 Posts
Status
