1 - 2 of 2 Posts
I'm finding that even though I've got the colours looking something like, VGA is causing some odd problems on my 40in Sammy. For example, when using the MCE, the blue background shows up the gradient from light to dark blue instead of blending, if you know what I mean. It's the same when if you're on the dash and press the guide button, and the blades go darker in the bakground. I don't get this with component.
Discussion Starter · #2 ·
I've just gone back to component and now I'm getting the same affect using that connection as I am with VGA, which wasn't the case before the update from last week. Anyone else noticed a change in component quality since the update?
1 - 2 of 2 Posts
