Status
Not open for further replies.
1 - 2 of 2 Posts
I am aware that widescreen resolutions 1366x768, 1280x720, 960x540, 848x540 etc aren't currently supported by the VPL-HS10 projector in 75hz mode (DVI), but what is the situation when using VGA input/VGA cable?
Can you take full advantage of the 1366x768 resolution 75hz with VGA input?
Or can the picture be scaled from for example 1280x720 to 1366x768 when using VGA input?
There has been some talk about the projektor beeing able to handle 1360x768 56hz, but that isn't usable for using the projektor as monitor?
(like working -> writing, coding and stuff)
56hz gives me a headache... or am I missing something?
1 - 2 of 2 Posts
Status
