Status
Not open for further replies.
1 - 3 of 3 Posts
Is it possible to input the VGA output of a Radeon LE into the d-sub15 port of a Pioneer SD582 widescreen?
Any help here is gratefully appreciated!
Thanks, RD
Yes but you'll need to use powerstrip for custom resolution and timing...that is if that card supports custom resolutions. I have a Geforce2GTS attached to a Pioneer elite RP HDTV.
Same here. What resolutions and PowerStrip settings are you using? I haven't had time to fully test every one and I'm hoping you have had yours for a while and have found the best ones.
1 - 3 of 3 Posts
Status
