1 - 3 of 3 Posts
A search turned up many similar questions but no direct answer to mine. I saw a cable online that is VGA male to HDMI. Will this work to use my 1080P TV as a monitor. No HDMI or DVI out on the PC, no VGA in on the TV. If the computer supports 1920X1080, can I use the cable to send that signal to the TV? Thanks in advance...
John
Discussion Starter · #2 ·
Well, a deeper drill down into the search gave me the answer. VGA=analog, HDMI=digital so it won't work...
John
1 - 3 of 3 Posts
