Status
Not open for further replies.
1 - 3 of 3 Posts
I want to show the display from my laptop to a plasma via VGA.At the same time, output from the first plasma to a second plasma via RCA.
Is it possible to get output video from the RCA if the signal source is from VGA?
Moderator
If the plasma has video outputs, it should be no problem. But does any plasma have component outputs? (or any video outputs) What about splitting the VGA from the laptop?
larry
What you need is a VGA-> Component Transcoder such as the Key Digital Systems KD-VTCA3. For approx $150-$200, you can drive both plasmas simultaneously -one on VGA and the other on Component Video.
1 - 3 of 3 Posts
Status
