Status
Not open for further replies.
1 - 4 of 4 Posts
Ok I just got a VGA to RCA breakout cable and I have a question.
1. My hdtv has 5 rca connections for one hd signal. labled "1.) Y/G 2.) Pr/R 3.) Pb/B 4.) H 5.) V. what color RCA plug goes to what connection?
2. Does anyone have some "Powerstrip" settings that work well on a Mitsubishi 46" 16:9 HDTV model# WT-46809 ?
Thanks for your time helping a newb such as I.
My system
MSI KT7-turbo (Motherboard)
AMD T-bird 1.3 ghz
768 PC-133 RAM
PNY GeForce3 TI500
Sound Blaster Audigy Platinum
16x DVD
Plexwriter 40x CDRW
Not sure about the powerstrip settings, but:
Y/G = Green
Pr/R = Red
Pb/B = Blue
H (Horizontal Sync) = Gray
V (Verticle Sync) = Black
I'm not 100% sure on the last two, they might need to be switched to H=Black, V=Gray.
Good Luck.
Depending upon the cable, the sync may be different:
H (Horizontal Sync) = White
V (Verticle Sync) = Yellow
1 - 4 of 4 Posts
Status
