Textf>
HDTVs are now beginning to have RGB interface connectors that look like a VGA connector. However, they are not. The question is does anyone make an interface box that would convert from VGA, SVGA, XVGA (available on newer Macs and certainly convertible from older ones) to the RGB interface on the newer HDTV systems? Or, convert to the "Multi-Scan" Component Video interface?
I have checked with Apple Tech Support and they are not aware of the interface specs as well as with Pioneer tech support who also does not know of an interface. Pioneer only stated that the interface is to an HDTV tuner output and conforms to the following specs:
Input: "Multi-Scan" Component video with
three signals - Y, PB (cB) and Pr (Cr ) (for output from DVD players or similar) -
Format Horizontal Freq Vertical Freq
480I 15.734kHZ 60hz
1080I 33.75 kHZ 60 hz
480p 31.468 kHZ 60 hz
Input: RGB (D-sub 15 connector - looks like VGA connector) with 5 signals - R, G, B, H and V (output from digital tuners and similar) -
1080i 33.75 khz 60 hz
The above interface specs are from Pioneer Tech Support and are specifically addressed to the Pioneer Elite Pro-710 HD High Definition Rear Projection TV.
Anybody know if something exists to interface?
http://www.avsforum.com/ubb/smile.gif
480I 15.734kHZ 60hz
