Status
Not open for further replies.
1 - 5 of 5 Posts
· Registered
What a joke, this thing has two bulbs. I wonder how much it costs.
EPOCH D-2200
SPECIFICATIONS
HDTV/DTV Ready, accepts interlaced and progressive scan signals
1080i, 720p, 480p Direct Input
Built-in Scaler with motion interpolation for film-like images
True XGA (1024 x 768) with SXGA compressed
Micro Lens Assembly for better blacks
MWahaha..doesn't this act to INCREASE light output!
Dual Lamp System for long life and high brightness
3-D Comb Filter
Exclusive Smoothing Circuit for clean outlines and edges
10-bit Digital Gamma Correction for better color reproduction
Screen Sizes from 30" to 300"
85% Center-To-Edge Uniformity for light output
Electric Digital Zoom
Picture-In-Picture between RGB and Video inputs
Backlit Wireless Remote Control with mouse functions for computer control
Lens Shift for wide range vertical position adjustment
Projectors Can Be Stacked for larger images
1.3" TFT Polysilicon LCD Panels (786,432 pixels x3 = 2,359,296 total pixels)
Power Zoom and Power Focus
RS-232 Computer Port for system control
Built-in Stereo Speakers with audio inputs and outputs
Black or Blue Background with picture mute
Two RGB, Component, S-Video, and Composite Inputs
RGB Output
Multiple Aspect Ratios
Scans from 15kHz to 80kHz (accepts line doubler, tripler or quadrupler)
Wireless Mouse Port for computer control
Two Long-life (2,000 hour) Bulbs-can be used independently to double time between replacement (to 4,000 hours). User replaceable.
Front/Rear/Ceiling/Floor Projection Modes-on-screeb display menu
Automatic Power Save Feature with countdown timer
Five Language Choices- English, German, French, Spanish, Japanese
Multi-TV System and voltage (PAL. SECAM, NTSC, 100V/240V)
13-1/16"W x 5-9/32" H x 18-1/2" D. Weight: 20.3 lbs.
Excellent Picture Quality with a host of multimedia features
· Registered
I've seen some very high contrast LCD projectors with MLA. I believe it does increase contrast because the lens redirects light away from the transistor for each pixel. It is possible that the transitor scatters and/or changes the polarization of light travelling through it, reducing the amount of light passing through could increase the measureable contrast.
By high contrast I mean up in the 600:1 range (measured on/off, not specs). MLA contrast enhancement seems like the most plausible explanation.
Maybe someone with more knowledge of LCD technology can clarify this?
Kam Fung
· Premium Member
David,
"This is a means of increasing brightness....and thus contrast...I do not believe this does anything for the black level, which is why I laugh."
As pointed out in another thread you started, increasing brightness does not necessarily have anything to do with contrast. And as Kam rightfully points out, redirecting light so that instead of scattering and reducing contrast it usefully increases pixel illumination, both increased brightness and contrast can be achieved simultaneously.
· Registered
Discussion Starter · #5 ·
Yes, but what I stated in another thread that was not perpetuated was that if you increase the lumens in a given projector, which has a limited capabillity to block light to produce absolute black, then you inherintly increase the black level.
THAT is why I laugh, because Vidikron, in esence, says that they increase brightness (with MLA), and thus black level, which I do not believe can go hand in hand with digital projectors of today.
However, as you correctly point out, this does NOT mean it can't do anything for contrast.
1 - 5 of 5 Posts
Status
