ZT60: We'd like to connect the audio out to our legacy analog preamp, tuner, & power amp 2.0 sound system.
Application: OTA reception (no cable or satellite), as well as video streaming, Blu-Ray, and DVDs.
I'm aware Viera plasmas lack analog audio out.
In searching AVS, I found:
1. Are there obvious lip sync issues?
2. Are there any other recommended methods (HDMI or USB) for outputting audio from a Viera to a DAC that would provide correct synchronization and/or remote controlled variable audio output?
Our other option is to use our Samsung DTB-H260F instead of the Viera internal tuner. It provides:
However, the audio is not always in sync with the video even though both the audio & video are coming from the same source, the DTB-H260F.
3. Is there a way to solve the lip sync issue?
4. Or, is a soundbar the most cost-effective way to have high-quality synchronized audio & video? Thank you!
- Using the digital audio out + a DAC is one solution for analog audio output.
- For OTA applications one should select a DAC that also includes DD & DTS such as Fiio D07 or Gefen GTV-DD-2-AA .
- There were some concerns that the audio may not always be in sync with the video.
- The Viera digital audio out is fixed, not variable, and our legacy preamp lacks remote control. (A mute is essential for commercials.)
- HDMI & component video (as well as S-video, & composite outs)
- Variable analog audio out w/o requiring a DAC (as well as optical DD out)
- Remote control
- EPG
