Status
Not open for further replies.
1 - 20 of 35 Posts
· Registered
I'm debating between the Sony 34" widescreen HDTV CRT and a 46" Samsung DLP. The viewing distance will probably be about 15 feet. Is this distance too large for the smaller choice?
· Registered
At 15' I'd say only a 50"+ widescreen display would do. Even the 46" DLP will be a little small for that viewing distance. I'd check out some of the 51" or 57" CRT RPTVs or perhaps a bigger DLP, if budget allows.
· Registered
Discussion Starter · #3 ·
Thanks Matt. I think I could pick up a 50" DLP for around $2400, which is reasonable. While the RP CRT would be cheaper, I've heard the resolution/viewing angle aren't as favorable on those.
· Registered
 This web site suggests that you get a 60" TV. Basically, get one as big as possible according to these people. I'd agree that 34" is too small for 15' away. I have a 34" and would not want to be further than I am now (7')...
· Registered
I think all of the choices mentioned so far are way too small for your 15 ft. viewing distance. In fact, barring any insurmountable obstacles (too much light, for instance), I wholeheartedly recommend purchasing a projector instead of a television. I believe you should be able to find a projector/screen combo for roughly the price of the 46" DLP TV you mentioned. And in my opinion, current digital front projectors offer superior picture quality to current digital rear-projection sets.
For movies, I myself prefer a comfortable viewing distance of about 2.25 the picture's width (on the small side compared to other projector owners), which in your case would yield a screen size of 80" wide, 92" diagonal. Of course you could always go smaller to cater to lower quality material. Either way, a simple tabletop setup in front of your seating position should suffice. You won't find any television anywhere near that size for the kind of money you're thinking of spending.
· Registered
You certainly would need to consider room lighting if you're going to use a FP.
· Registered
Discussion Starter · #7 ·
Front projection is not an option. The living room is a rectangular shape, which leaves two options:
1. Put the television on the shelf and place the couch on the longer side of the rectangle. This provides little room for the coffee table in front of the couch, and makes speaker placement difficult. Viewing distance would be roughly 7 feet.
2. Place the television against the short side of the rectangle, and the couch on the opposite end. This allows optimal speaker placement, and the subwoofer will be nearest a wall that's unoccupied by neighbors. The viewing distance is about 15' at this location.
· Registered
I don't understand how any of this has to do with not being able to use a projector. It seems that the option you are choosing - #2, which is a 15' viewing distance, would be the best choise for using a FP.
· Premium Member
Front Projectors aren't for everyone and don't work well in all living rooms.
· Premium Member
1. Put the television on the shelf and place the couch on the longer side of the rectangle. This provides little room for the coffee table in front of the couch, and makes speaker placement difficult. Viewing distance would be roughly 7 feet......
How about getting a 37" or 42" Plasma instead for this scenario? Since it's slimmer, you can push it back another foot or two to increase your viewing distance to 8-9 feet which would be just about perfect. You can get the Panny commercial ED displays for not too much more than a Sony XBR960.
· Registered
i'd move the couch closer.
· Registered
Discussion Starter · #16 ·
I can place the couch on the long end of the living room, which would make the viewing distance about 7 feet. However, that would leave about 4 feet between the coffee table and the fire place. Also, the couch would be off-center from the TV location, and the placing of the surround speakers wouldn't work.
If I move the couch up from the short wall where I'm planning to place it, I'll essentially cut off the ability to place additional seating anywhere. Picture this, the room is about 10 feet by 15 feet. On the two short ends are walls. The one long end has a wall, fireplace and exit door out to the patio, while the other long end has the walkway connecting the front entrance to the bedroom entrance. The more I think about it, the only way to have another seating section other than the couch would be to put the TV on the long wall. But, as I said, the surround speakers and tv location would be all goofy.
· Registered
Ahhhhh...now I get the picture.
So you viewing distance will actually be smaller than 15'. Since the longest wall is only 15', the depth of the tv is about 2',give about 1-2' of space between the wall and tv, the couch depth, if placed right up against the wall, will keep your head about about 1-2 ft' from the wall...so far 4 to 6 feet taken from the 15' is 9-11 feet viewing distance.
Plus, I would move the couch about 2-3' away from the wall in order to be able to place the surrounds not just out to the sides, but also behind you.
Yeah, you should have no problemos at all w/a 34".
· Registered
Way too small. I currently sit around 7 feet from my XBR910 and it is perfect. However I just bought a house and I will be sitting more like 15 to 20 feet away in the new family room. I may have to move my unwatched (since getting the XBR910) 47" Panny RPTV for main viewing duties now. :(
· Registered
No its not. Read the post before yours.
1 - 20 of 35 Posts
Status
