Status
Not open for further replies.
1 - 3 of 3 Posts
Hi DTC 100 specialists.
We need your help with this unit. The spec data says that
the output is 33,7 kHz with RGB and seperate H and V synchronisation
TTL posivite.
Although our quantum data HDTV generator can generate that signal
and we are nicely locking on it, the GVC 1280 refuses the DTC
100 signal in RGB mode. The specs do not indicate any difference so
we are in trouble. The DTC 100 when fed through the RCA RGB-YPrPb
transcoder is working. So the problem must have someting to do with
the synchronisation signals. Anybody has a scope with a drive,
so he can make screenshots of the actual H and V sync signals ?
Your email with these shots is much appreciated and buys you drinks
at CEDIA show.
make it so
spatz
Just to add to Uwe's request. He does not have a DTC100 over in Germany and has been relying on me to test. Also, the DTC100+VHC300 combo does NOT sync up with the Vigatec either....it comes close...but no cigar yet.
We are looking for someone that could scope their DTC100 and send us the photos since sending Uwe a DTC100 would be pointless...no sat or OTA signal.
Tom
Nevermind folks...problem solved! The GVC1280/Dune now works with the DTC100 perfectly using its RGB output. This is great news since both inputs 7 and 8 also accept HDTV via RGB, leaving input 6 for HDTV via YPrPb or RGB.
Uwe will now pretty the menu up with a specific setting for the DTC100 so that you can just select it, or auto detect it.
Tom
1 - 3 of 3 Posts
Status
