1 - 1 of 1 Posts
Hi all
Has anyone played much with the new Sky Control panel from Vivint? Does it have a local webserver?
I have one of the Go!Control units from 2gig and I quite like it. My main gripe with it is that I can't access it directly over my local wifi. The new units are supposedly internet enabled, but the go!control unit advertised that as well and what they really meant was it had a GSM radio that talked to alarm.com. That's not what I want. I want to connect to my home wifi and from there be able to see what's open/closed and ideally be able to use zwave control. Basically everything you can do standing in front of the unit. The marketing stuff is pretty, but it's not clear if you're talking to the unit or the monitoring service.
1 - 1 of 1 Posts
