1 - 3 of 3 Posts
Hey all,
I had recently purchased this set and sometimes, I leave it on overnight (fall asleep with the set on)
Occasionally, I will wake up to find that the picture is completely gone (black screen) but the sound is still playing from whatever channel is on at the time.
I've checked the option for 'Auto power off' under the 'Timers' settings which was 'Off' so that cannot possibly be it.
I was unable to find any other similar functions that would shut off the display such as some sort of screen saver or anything else to this extent.
Am I rolling onto the remote in my sleep and hitting something? Will the display turn off automatically (without fiddling with any options) after a set period of time of inactivity?
Thanks in advance!
Link to model in question -  http://store.vizio.com/e390ia1.html
1 - 3 of 3 Posts
