1 - 1 of 1 Posts
When I set up my LCD and Time Warner DVR with component cables things were fine. But when I plugged in the HDMI and turned on the tv, the screen has a green tint. I usually have to flip a few channels and then it will go back to normal. I think I'm noticing a trend that the green tint only goes away when I switch from HD to regular or vice versa.
I had two HDMI cables sent from monoprice and both have the same problem. Not sure if it's something with the tv, or the Time Warner Cable Box, or the HDMI cables... has anyone else ever had this problem?
Thanks for any advice or help.
1 - 1 of 1 Posts
