1 - 2 of 2 Posts
Hi guys, I have a vizio e421va and the auto-dim is driving me nuts. I hate it and just want to disable it.
Every vizio thread I have read shows this can be done in the picture settings, but I don't see anything. All I have is "Ambient Light Sensor" which doesn't seem to do anything if I turn it on or off.
Is there a service mode for this tv to disable it?
Try labeling the input you're using as "PC" or similar in your TV's options/menu.
This may sound odd and may not have any effect with your Vizio TV, but, I've found that with certain TV brands labeling a given input as PC fully disables quite a bit of "superfluous" processing. Of course, the PC label may have no effect at all for if you're not using certain inputs. A long shot, but possibly worth a try.
1 - 2 of 2 Posts
