Hello,
I have a Vizio VHT510 5.1 audio system... one of the subwoofer/(2) satellite speaker/soundbar kits that Vizio put out a bit ago. My issue is this:
the audio cables that run from the powered subwoofer to the two rear sat. speakers are no longer viable. Vizio seems to have used proprietary hardware in their connections, requiring a plug which is my issue (I don't have it)... does any one out there have either a set they are willing to part with or a workaround?
The satellite speakers have a small male ended two prong port that is soldered inside to the speaker wire. This goes for the powered sub as well. Is anyone familiar with this model?
Thanks for any input.
Edit/ yes I did contact Vizio and they pointed me to Ebay or Best Buy.
