Status
Not open for further replies.
1 - 7 of 7 Posts
Pff, after searching and reading the multiple posts I still do not seem to see the answer. Do I overlook something?
I have Cineplayer 1,5 and Windvd and I am not using Zoomplayer.
How do I initiate vmr9 in Cineplayer or for that matter in WInDVD platinum?
How do I make ffdshow work for WinDVD? Do I need something to change in the registry like for Cineplayer?
I use Nvidia latest drivers 43.45 and have an AMD XP 1900+ and WinXP
thanks in advance
jamoka:
I think he wants it for DVD, not media... And I believe that graph isn't using VMR9.
WinDVD can be set to work in directshow, but even then I don't think it'll work with VMR9 (as it requires special setup).
Discussion Starter · #5 ·
Well
That is clear and short.
I will buy Zoomplayer
To use ffdshow for windvd Platinum, how is that done?
just configuring does not seem to give any perceptible effects. also I do not see my cpu load changing (taskmanager)
1 - 7 of 7 Posts
Status
